I can’t advance from here:
make --directory=aw-watcher-afk build
make[1]: Entering directory 'C:/Users/nelson/activitywatch/aw-watcher-afk'
poetry install
Installing dependencies from lock file
Package operations: 7 installs, 0 updates, 0 removals
- Installing pyHook (1.5.1 https://github.com/ActivityWatch/wheels/raw/master/pyHook-1.5.1-cp36-cp36m-win_amd64.whl)
[EnvCommandError]
Command ['C:\\Users\\nelson\\AppData\\Local\\pypoetry\\Cache\\virtualenvs\\aw-watcher-afk-p_uBid-B-py3.6\\Scripts\\pip.exe', 'install', '--no-deps', 'https://github.com/ActivityWatch/wheels/raw/master/pyHook-1.5.1-cp36-cp36m-win_amd64.whl#egg=pyhook'] errored with the following return code 1, and output:
pyHook-1.5.1-cp36-cp36m-win_amd64.whl is not a supported wheel on this platform.
You are using pip version 18.1, however version 20.2b1 is available.
You should consider upgrading via the 'python -m pip install --upgrade pip' command.
Makefile:4: recipe for target 'build' failed
make[1]: *** [build] Error 1
make[1]: Leaving directory 'C:/Users/nelson/activitywatch/aw-watcher-afk'
Makefile:28: recipe for target 'build' failed
make: *** [build] Error 2
I’ve google how to upgrade pip, but turns up I’m using the last version:
nelson@aspireone MINGW32 ~/activitywatch (master)
$ pip --version
pip 20.1.1 from c:\users\nelson\appdata\local\programs\python\python36-32\lib\site-packages\pip (python 3.6)
by the way, the file pip want to download is compiled for amd64 architecture -> pyHook-1.5.1-cp36-cp36m-win_amd64.whl
So, I don’t know what else to do…
