Hi, how can I fix this issue when starting up? Doesn’t work with or without admin rights, latest version:
C:\Program Files\activitywatch>aw-server.exe
WARNING:root:Could not import pymongo, not available as a datastore backend
INFO:aw_server.main:Using storage method: peewee
2020-05-15 08:34:59 [INFO ]: Using storage method: peewee (aw_server.main:26)
INFO:aw_server.main:Starting up...
2020-05-15 08:34:59 [INFO ]: Starting up... (aw_server.main:31)
INFO:aw_datastore.storages.peewee:Using database file: C:\Users\user\AppData\Local\activitywatch\activitywatch\aw-server\peewee-sqlite.v2.db
2020-05-15 08:34:59 [INFO ]: Using database file: C:\Users\user\AppData\Local\activitywatch\activitywatch\aw-server\peewee-sqlite.v2.db (aw_datastore.storages.peewee:90)
* Serving Flask app "aw-server" (lazy loading)
* Environment: production
WARNING: Do not use the development server in a production environment.
Use a production WSGI server instead.
* Debug mode: off
ERROR:aw_server.server:[WinError 10013] Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig
2020-05-15 08:34:59 [ERROR]: [WinError 10013] Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig (aw_server.server:93)
File "__main__.py", line 3, in <module>
File "aw_server\main.py", line 33, in main
File "aw_server\server.py", line 94, in _start
File "aw_server\server.py", line 91, in _start
File "site-packages\flask\app.py", line 943, in run
File "site-packages\werkzeug\serving.py", line 814, in run_simple
File "site-packages\werkzeug\serving.py", line 774, in inner
File "site-packages\werkzeug\serving.py", line 666, in make_server
File "site-packages\werkzeug\serving.py", line 577, in __init__
File "socketserver.py", line 456, in __init__
File "http\server.py", line 136, in server_bind
File "socketserver.py", line 470, in server_bind
OSError: [WinError 10013] Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig
[17208] Failed to execute script __main__
