Hello, I am running AW on two separate users in Xubuntu 18.04 LTS. It is set as an autostart application for each of the two users. When User 1 starts a session everything goes smoothly, but when User 2 starts a session after User 1 has closed his, a notification with the following text appears:
Module aw-server quit unexpectedly
2019-11-03 17:34:59 [INFO ]: Using storage method: peewee (aw_server.main:26)
2019-11-03 17:34:59 [INFO ]: Starting up… (aw_server.main:31)
2019-11-03 17:34:59 [INFO ]: Using database file: /home/user2/.local/share/activitywatch/aw-server/peewee-sqlite.v2.db (aw_datastore.storages.peewee:90)
2019-11-03 17:34:59 [ERROR]: [Errno 98] Address already in use (aw_server.server:93)
Furthermore, if User 2 closes his session and User 1 opens another one, three notifications appear, with the following texts:
Module aw-watcher-afk quit unexpectedly
2019-11-03 17:39:21 [ERROR]: Another instance is already running, quitting. (aw_client.singleinstance:38)
Module aw-watcher-window quit unexpectedly
2019-11-03 17:39:23 [INFO ]: Using storage method: peewee (aw_server.main:26)
2019-11-03 17:39:23 [INFO ]: Starting up… (aw_server.main:31)
2019-11-03 17:39:23 [INFO ]: Using database file: /home/user1/.local/share/activitywatch/aw-server/peewee-sqlite.v2.db (aw_datastore.storages.peewee:90)
2019-11-03 17:39:23 [ERROR]: [Errno 98] Address already in use (aw_server.server:93)
It seems that AW does not terminate when a session is closed. For the moment, I have to shut down the computer on every user change, which is a nuisance. How can this be fixed?
Thanks and keep up the good work!
