It is more convenient for me to set it to 10 seconds for example. Maybe there is a temporary fix that I can apply locally?
This is possible to change today in a condo file for aw-watcher-afk. It’s described here where you can find the default config file
https://docs.activitywatch.net/en/latest/getting-started.html#config
But yes, it would be more user friendly to provide such an setting in the web-ui
Thanks for your solution! Will try it out now.
It might be useful to know for other people that applications like Caffeine may tamper with the afk-watcher. At least this was the case for me – running MacOSX 10.13
Probably it would be useful to specify this in the docs.
No other problems detected so far.
