I had no problem installing and starting ActivityWatch, however it does not start atomatically at boot up. I have to go to the file aw-qt and click on it to start it. How can I make it start automatically when I turn on the computer: Linux-Mint 19.3, desktop, Chrome browser.
It’s hard for us ActivityWatch developers to add an built-in autostart option because we support so many platform and they implement that differently.
However, it is easy to do manually yourself, see this link for you specific case with LinuxMint https://askubuntu.com/questions/209684/where-can-i-find-the-startup-application-list-in-a-cinnamon-desktop
loleg
March 3, 2021, 1:37pm
3
I appreciate the fact of having many platforms to juggle. Nevertheless the Linux community is where you can find some of the most passionate users of privacy preserving and open source software, who (like me) are interested in the quantified self topic. Currently Arch Linux is officially supported with an autostart installer. Which is a great start, and there is work happening to widen support to other distros.
Besides tipping the project on Open Collective I am leaving a note of encouragement on these open issues:
opened 01:13PM - 11 Jul 16 UTC
!next
priority: low
type: outreach
Right now you pretty much need to be a developer to start using ActivityWatch.
One easy improvement we could make is to create a bash one-liner that installs ActivityWatch (much like the one-liner used to install brew). In the future (when we leave beta) we'd likely have to distribute installers/packages.
Would require some kind of process management for aw-server and watchers.
Must do:
- [x] Linux: Build a portable `.zip`
- [x] macOS: Build a portable `.zip`
- [x] Windows: Create a portable `.zip`
May do (secondary goals):
- [ ] Make ActivityWatch start on login for all installation methods (when possible, have a checkbox for those who want to opt out). See #116.
- [ ] macOS: Build a macOS `.app` (in progress, but stalled: https://github.com/ActivityWatch/aw-qt/pull/28)
- [x] macOS: Create a [homebrew formula](https://docs.brew.sh/Formula-Cookbook). Done by @freayd, install using `brew cask install activitywatch`.
- [ ] Linux/Debian: Build a `.deb` ([work in progress](https://github.com/ActivityWatch/deb-activitywatch-bin))
- [ ] Linux: Create an [AppImage](http://appimage.org/)? ([Wikipedia](https://en.wikipedia.org/wiki/AppImage))
- [ ] Linux: Create a flatpak. See #476.
- [x] Arch Linux: Create a PKGBUILD and upload to AUR ([done](https://aur.archlinux.org/packages/activitywatch-bin/))
- [x] Windows: Create an installer using ~~[NSIS](https://sourceforge.net/projects/nsis/) or [WiX](http://wixtoolset.org/)~~ Inno Setup.
- [x] Windows: Create a Chocolatey package (done: https://github.com/chocolatey/chocolatey-package-requests/issues/552)
And finally:
- [x] Put installation instructions in README
<bountysource-plugin>
Want to back this issue? **[Post a bounty on it!](https://www.bountysource.com/issues/35920349-create-installation-methods-for-non-developers?utm_campaign=plugin&utm_content=tracker%2F35920020&utm_medium=issues&utm_source=github)** We accept bounties via [Bountysource](https://www.bountysource.com/?utm_campaign=plugin&utm_content=tracker%2F35920020&utm_medium=issues&utm_source=github).
</bountysource-plugin>
opened 11:20AM - 22 Mar 20 UTC
area: ci
improves: tech debt
So I've been playing with this in #382, and I'm impressed.
Motivations:
-… Better build times (especially for macOS and Windows), see #370.
- Integrated into GitHub, better UX in general
- Easier/cleaner config (especially with regards to multi-platform support)
- Seems more reliable
- Not a high bar to beat
- Travis has had outages, build backlogs, builds stalling
- I've been getting "An error occurred while generating the build script." frequently recently (the last two days) for macOS builds.
- It makes us able to finally get rid of Appveyor and unify our CI process
- It allows for more advanced automation, such as automating creating releases with changelog and everything.
I'm seriously tired of mucking with Travis and Appveyor, especially due to the long build times, so pretty excited about getting this done, so we can scrap them.
### Subtasks before ready to completely migrate to GitHub Actions:
- [x] Upload build artifacts on every build
- [ ] Upload releases to GitHub releases
- Can even automate the creating of the release, including generating the release description & changelog. See: https://github.com/actions/upload-release-asset
- [x] Add caching for `aw-server-rust/target`
- [x] Build aw-server-rust in debug mode on non-releases (for faster builds), see https://github.com/ActivityWatch/aw-server-rust/pull/100
- [ ] Test builds on all platforms
- [x] Linux
- ~~Problems found, see comments.~~
- Fixed in #604
- [ ] Windows
- [x] macOS (done in https://github.com/ActivityWatch/activitywatch/issues/388#issuecomment-751726505)
- [x] Problems anticipated on versions of macOS older than the version used in CI, probably need to do some xcode-select magic (done in https://github.com/ActivityWatch/activitywatch/pull/544/commits/9f0f7c7af389cd878889b60e9c9b00c1bb878d7f)
- [x] Stumbled into some issues... Might work now, but should check with otool to be sure: https://stackoverflow.com/questions/17143373/determine-minimum-osx-version-a-binary-was-compiled-for (done in https://github.com/ActivityWatch/activitywatch/pull/544#issuecomment-751801675)
### Progress on moving module repos to GitHub Actions:
- [x] aw-server (https://github.com/ActivityWatch/aw-server/pull/73)
- [x] aw-server-rust
- [x] aw-webui
- [x] aw-qt (https://github.com/ActivityWatch/aw-qt/commit/20261da3f38731f30726b15531943bc9e5332de1)
- [x] aw-core (https://github.com/ActivityWatch/aw-core/pull/89)
- [x] aw-client (https://github.com/ActivityWatch/aw-client/pull/51)
- [x] aw-watcher-afk (https://github.com/ActivityWatch/aw-watcher-afk/commit/4b9eea5e1bd71e90f07bee159ae17ab03615a8c9)
- [x] aw-watcher-web (https://github.com/ActivityWatch/aw-watcher-web/pull/63)
- [x] aw-watcher-window
- [x] activitywatch.github.io (https://github.com/ActivityWatch/activitywatch.github.io/issues/13)
### An overview of migration progress can also be seen on the [CI overview page](https://activitywatch.net/ci/)
opened 10:00AM - 26 Jan 21 UTC
[Nixpkgs](https://github.com/NixOS/nixpkgs) packages thousands of open source so… ftware and nix package manager can be installed on both linux and mac, adding a package definition to build activity watch would further help in simplifying installing, updating and maintaining activity watch.
Initially the package can derived using the existing binary releases, later the build process can be fully integrated using nix to allow for fully reproducible builds.
More info here: https://nixos.org/manual/nixpkgs/stable/#python
