How do I ensure that AW goes on immediately when I switch on my Mac and start working, or can it track while not on? I keep forgetting and losing hours tracked while it is off.
“ Head to System Settings > General > Login Items to see a list of your Mac’s startup applications. You can disable programs that start when macOS boots and add your own startup applications from here.”
From googling add program on startup Mac.
This is a normal thing for operating systems to support. I don’t have a Mac but it was easy to enable this on Linux and windows, so it shouldn’t be too bad on Mac. Good luck!
Thank You so much!
This worked; I did not even know I could do that on a Mac. It has solved so many other problems as well, this one solution!
