AVAST Antivirus deleting app
Hi, AVAST detecting viruses and deleting aw-qt.exe file
https://www.virustotal.com/gui/file/c4c73c51018e7b91147f105af2d8278216a29cd086269c6376dc148a30cb9f76
I can confirm. It did not happen with previous installations.
It used to happen with previous versions too, but eventually Avast stopped reporting it as a false positive.
Anti-virus false positives are being tracked and reported to vendors here: Submit false positives to antivirus vendors · Issue #181 · ActivityWatch/activitywatch · GitHub
The long-term solution for this is to codesign releases, which should drastically reduce false positives.
Hi,
If you are facing any trouble with any types of antivirus you can contact with Antivirus Tales is a unique platform that offers quick solutions and expert assistance for all antivirus products in one place. Antivirus users can access effective and easy-to-follow solutions to any problem, from issues updating the antivirus product and the product key not working to product installation issues and more.
