Hello, trying to build form sources (on a Macbook/latest Catalina) using these instructions.
https://docs.activitywatch.net/en/latest/installing-from-source.html
First got an error that this dependency is missing (referenced by poetry.lock and pyproject.toml).
https://github.com/ActivityWatch/wheels/raw/master/pyHook-1.5.1-cp37-cp37m-win_amd64.whl
Updated it to:
https://github.com/ActivityWatch/wheels/blob/master/pyHook-1.5.1-cp37-cp37m-win_amd64.whl
Then got this build error:
Getting this build error. Thoughts?
(venv) âžś aw-watcher-afk git:(cf4168a) poetry install
Installing dependencies from lock file
Warning: The lock file is not up to date with the latest changes in pyproject.toml. You may be getting outdated dependencies. Run update to update them.
BadZipFile
File is not a zip file
at ~/.pyenv/versions/3.7.9/lib/python3.7/zipfile.py:1325 in _RealGetContents
1321│ endrec = _EndRecData(fp)
1322│ except OSError:
1323│ raise BadZipFile(“File is not a zip file”)
1324│ if not endrec:
→ 1325│ raise BadZipFile(“File is not a zip file”)
1326│ if self.debug > 1:
1327│ print(endrec)
1328│ size_cd = endrec[_ECD_SIZE] # bytes in central directory
1329│ offset_cd = endrec[_ECD_OFFSET] # offset of central directory
