Can someone walk me through getting yearly data?
Hi!
I am a lawyer and I use AW to track my billable hours. I started tracking in February and so far I’ve been using the monthly view, but now I need to see my data year-to-date. Unlike the people in these issues, I do not see a “Yearly” option in the Summary view dropdown menu, only day/week/month/7 days/30 days. The Timeline view also says that it has a maximum of 31 days. I see that another thread titled “Week, Month and Year view on the Activity Tab of the Web UI” (I can’t put more than two links) asked for a week, month, and year view, which was marked as solved, but again I can’t see a way to get yearly data.
I know I can export all of my data as JSON, but I’m not a coder and I have no idea how to work with that data to show me how much time I’ve spent in each category.
I’d appreciate if someone could give me a step-by-step on (1) how to show the yearly data on the Summary page, which would be my preferred solution, or (2) how to manipulate the JSON data to calculate per-category times.
Sorry if I’m missing something obvious, and thank you for the help!
Go to Settings and then scroll down till the end, there’s a selection “Show yearly time range” this should fix it :+1:t2:Also funny that you mentioned my thread because I can confirm it got WAY better since, I already mentioned in Aug '24 post that the issue was fixed but even afterwards I felt like it got slightly improved so you should be good :slight_smile: (keep in mind though that it still can lag a little bit depending on your device etc., I had ~2,400h in 2024 and it took around 30sec to load, so very good)
