I have been using the app for a while now, and then suddenly this month it stopped working with the dashboard. I cannot connect to localhost:5600.
It gives the reason ERR_CONNECTION_CLOSED.
Also log file says this:
2024-08-08 13:42:06 [INFO ]: Started aw-qt… (aw_qt.main:53)
2024-08-08 13:42:06 [WARNING]: Found matching file but was not executable: “deleted for privacy”\AppData\Local\Programs\ActivityWatch\aw-qt.desktop (aw_qt.manager:64)
2024-08-08 13:42:06 [WARNING]: Found matching file but was not executable: “deleted for privacy”\AppData\Local\Programs\ActivityWatch\aw-server-rust\aw-server.service (aw_qt.manager:64)
2024-08-08 13:42:06 [INFO ]: Found 4 bundled modules (aw_qt.manager:85)
2024-08-08 13:42:06 [INFO ]: Found 0 system modules (aw_qt.manager:119)
2024-08-08 13:42:06 [INFO ]: Starting module aw-server (aw_qt.manager:148)
2024-08-08 13:42:06 [INFO ]: Starting module aw-watcher-afk (aw_qt.manager:148)
2024-08-08 13:42:06 [INFO ]: Starting module aw-watcher-window (aw_qt.manager:148)
2024-08-08 13:42:06 [INFO ]: Creating trayicon… (aw_qt.trayicon:206)
2024-08-08 13:42:06 [INFO ]: Initialized aw-qt and trayicon successfully (aw_qt.trayicon:262)
It used to work fine. I don’t want to reinstall yet since I have 1 months of data I need to have a look at.
Thanks.
