Category Oddities & Viewing Errors
I found an error in how the category sunburst/category tree displays when there are multiple for some reason. OneDrive Link with Screen shots of the multiple states
I have work/PowerPoint/Studying & work/PowerPoint/Editing categories and it is not properly displaying when the Sub Category with the exclusion regex is below the Straight Text provided one…
  • In OneDrive
It is also not coloring the Top Windows correctly when the Straight Text one is blow the regex one, despite then showing the category correctly.
  • In OneDrive
What makes it weirder is that if the exclusion regex is in the parent category, the Text one works and shows up properly in both sections as well.
  • In OneDrive
Thought it does not work if either is a child of each other belowe the PowerPoint Category.
  • In OneDrive
Just in case the text is not directly legible.
  • Regex Exclusion | (?<!Protected\sView) - PowerPoint || (?<!\s-\sProtected\sView) -\sPowerPoint
  • Text Search | Protected View - PowerPoint
The Regex Works, and I want to separate the tracking of Protected View Powerpoints & normal creation/Editing of them.
