Hi there,
Can I use negative lookaheads in the regex for Categories like: (?!Job Quoter.* - Bob the Builder.*)
AW is saying that this regex pattern is “too broad”.
Edit: Oh I think I worked out why it’s saying it’s too broad. It’s because it’s way too broad! XD That regex would match literally anything I’m doing on my computer except being in a Job Quoter for Bob the Builder.
I changed it to: Job Quoter.* - (?!Bob the Builder.*) and this regex works as expected.
Answer to my OP is: Yes, you can use negative lookaheads - if you use them properly.
