Combine Activity Watch Data With Other Tracking Data
Hello guys,
I am working on a tool that aims to make it easy to merge and visualize data from different sources.
This allows combining your activity watch data with other tracking data (google fit, oura, local weather, thermometer…) as long as they offer data export.
Here is the link where you can import data from the window-bucket: Load Activity Watch data into Dataflexor.
Data from other buckets should also work with a little configuration.
If you need any help or have feedback, i am eager to hear about it.
I’d definitely recommend making it more explicit either in the privacy policy or the terms of service that the data collected and processes does not include the actual imported content, and that all processing is done locally. I spent a good 20 minutes looking over both documents before seeing the hint under the add table option.
also, would be nice to have plugins for direct api interactions.
cool tool though
Thank you for the feedback. I have added a hint in the privacy policy now.
Do you have any specific service that you would like to be integrated?
