Distribute the application
i am planning to make some changes to the code, and distribute the application, there are some code i need to keep private. is it ok to keep private and is it mandatory to add the citation in website. please let me know so that i can start working on it and distribute it
If i understand well, you have to provide the source code, check the license: activitywatch/LICENSE.txt at master · ActivityWatch/activitywatch · GitHub
You could either make a pluging or extension that doesn’t imply modifying the original code and keep that one private. But if you modify the original one you must respect the Intellectual Property and it’s distribution license.
