Hey,
I think the current way of categorizing might be too difficult.
Why can’t I just go to the Top Window Title page and right-click the elements on there to choose their category?
I think that this feature would make the application much easier.
Hey,
I would really like to see a feature like this since most of the programs I use end up “uncategorized” (eg. games).
Something like right-clicking on an activity on the view would be a much quicker way.
Writing regex pipe is also kind of clutter once you have enough items.
That would make this software so much more useful. The inability to easily categorize things makes it useless for analysis. I just keep logging things in the hope that in the future it becomes easy to categorize them and actually see how much time was spent in each area.
I think regex is fairly good enough if you get used to it. However, I guess a huge problem comes with its narrow and unreadable editing UI, which is just a line of input field.
e.g. Below is my random config file snippet using regex in a multiline form.
- id: end-of-file-fixer
exclude: |
(?x)^(
.*\/?cspell\.json|
.*\/?lazyvim\.json|
.*\/dot_wakatime\.cfg|
.*\/dot_warp\/themes\/.+|
.*\/font\-manager\/Collections\.json|
.*\/JetBrains\/.+\/settings\/.+|
.*\/private_dot_docker\/config\.json|
.*\/private_fcitx\/private_conf\/.+\.config|
.*\/private_fcitx\/private_profile|
.*\/(private_Code|vscode\/data\/user-data)\/User\/.+|
.*\/?(-|\.)lock(\.json|\.toml|\.ya?ml)?
At a glance it seems like a huge amount of regex lines, but once you get used to its syntax I’m sure it’s very easy to read and understand.
I think it is a decent starting point with not too much to implement.
What about something like this? Right clicking is not something that Activity Watch does out of the box, so I needed to create a mode button for it. I think this is more flexible than just having an “Add to category” button. Note that the gif below is a little old. Now, it only shows the buttons for uncategorized options.
These changes can be found on my fork: GitHub - RTnhN/aw-webui: Webapp for visualizing and browsing ActivityWatch data, built with Vue.js. · GitHub . If this is something that people like, I can work on adding a new release I have added a release that people can use. With the newest versions of ActivityWatch, you can just add an environment variable to a path and use a different webui instead of using the default one.
This is a copy from Catagorizations which is a duplicate but recent related feature.
It might be possible to also fix categorization regex rules to split on the | and make a list of filters rather than a string with |. I feel that editing that would be more user friendly rather than managing that gnarly long regex string. If I have some more time this week, I might try to implement that too.
EDIT:
It was a lot easier to implement something more user friendly. You can now edit the filter as a list. This just uses the same regex data structure as before, but it just splits on the | (with appropriate checking for escape characters) and creates a more easily manageable list. It then saves this as regex, so there are no major changes to the backend.
