Hello Team,
I have cloned ActivityWatch repo in MacOS and installed the required packages.
Also, perform the below command
make build
make package
make dist/ActivityWatch.dmg
when I’m running ./aw-qt from terminal it’s working fine but when I’m trying to run dmg file generated from dist on the double click installation not working.
