I’m attempting install editor watchers, and I’m having a few problems. When I installed ActivityWatch, I installed it in a folder on my C: drive. When I go to the AppData folder, there is also a folder there for ActvityWatch. Which one is the correct folder to install watchers to get the application to recognize them? I tried in the AppData folder, so I’m assuming it’s that one? Also, when I attempt to install the watchers for visual studio code as an extension, I can’t find the files anywhere to make sure those are in the right place. I was able to find the file for the visual studio extension.
Editor watchers don’t need to be moved to any folder. For example, the visual studio code watcher just needs to be installed from within visual studio code itself and then it runs automatically and reports to aw-server when vscode is running.
