Trying to install via AppImage under Bazzite Kde,
the file is set to run as a program, whenever I run it, it does nothing, opening via terminal gives more information, but as I’m new to it I’m not sure how to fix it.
2026-08-01 12:37:55 [INFO ]: Started aw-qt… (aw_qt.main:53)
2026-08-01 12:37:55 [WARNING]: Found matching file but was not executable: /tmp/.mount_activiy1eoBX/aw-qt.desktop (aw_qt.manager:64)
2026-08-01 12:37:55 [INFO ]: Found 8 bundled modules (aw_qt.manager:85)
2026-08-01 12:37:55 [INFO ]: Found 0 system modules (aw_qt.manager:119)
2026-08-01 12:37:55 [INFO ]: Starting module aw-server (aw_qt.manager:148)
2026-08-01 12:37:55 [INFO ]: Starting module aw-watcher-afk (aw_qt.manager:148)
2026-08-01 12:37:55 [INFO ]: Starting module aw-watcher-window (aw_qt.manager:148)
2026-08-01 12:37:55 [INFO ]: Creating trayicon… (aw_qt.trayicon:208)
/tmp/.mount_activiy1eoBX/aw-qt: symbol lookup error: /tmp/.mount_activiy1eoBX/libQt6WaylandClient.so.6: undefined symbol: wl_proxy_marshal_flags
File “PyInstaller/hooks/rthooks/pyi_rth_pkgres.py”, line 158, in
File “PyInstaller/hooks/rthooks/pyi_rth_pkgres.py”, line 36, in _pyi_rthook
File “PyInstaller/loader/pyimod02_importers.py”, line 419, in exec_module
File “pkg_resources/_init_.py”, line 31, in
File “zipfile.py”, line 6, in
ImportError: /tmp/.mount_activiy1eoBX/aw-server/lib-dynload/binascii.cpython-39-x86_64-linux-gnu.so: cannot open shared object file: Software caused connection abort
[97807] Failed to execute script ‘pyi_rth_pkgres’ due to unhandled exception!
/tmp/.mount_activiy1eoBX/aw-watcher-afk/aw-watcher-afk appears to have been moved or deleted since this application was launched. Continouation from this state is impossible. Exiting now.
/tmp/.mount_activiy1eoBX/aw-watcher-window/aw-watcher-window appears to have been moved or deleted since this application was launched. Continouation from this state is impossible. Exiting no
w.
