"High uncategorized time"
Activity tab shows High uncategorized time
But if I click on Category Builder, I see Unable to find bucket matching ‘aw-watcher-window_unknown’ (hostname filter set to ‘None’)
and down below
Common words in “Uncategorized” events
No words with significant duration. You’re good to go!
I encountered the same issue.
However, there is a workaround: go to the settings tab and under the “Categorization” chapter you’ll find a working link to the Category Builder.
My Category Building just hangs on “Loading” and error “Unable to find bucket matching ‘aw-watcher-window_unknown’ (hostname filter set to ‘None’)”
Any clues how to fix?
Workaround: In the category builder, click “show options” and change the hostname.
There is a bug with the stopwatch feature that needs to be addressed to fix this problem permanently: https://github.com/ActivityWatch/activitywatch/issues/1097#issuecomment-2687911846
Also related: How to set the default hostname in category builder? - #2 by cweiske
Same problem here. This solved it for me.
