iOS 15 introduces the Screen Share API, as well as support for Safari Web Extensions. Is it possible now to make an ActivityWatch app for iOS?
Unfortunately not. The new API does not let other applications retrieve the usage data, only manage restrictions.
Apple was very blatant in the announcement video for the API that “there is no way for anyone outside of your family, or even Apple, to know which websites you’ve visited, or which apps you’ve used”:
your good question and interesting information but i am not idea.
I believe that app is using monitoring through shortcuts + an safari extention? That would be my guess, as previous commenters are correct in saying the screentime API does not open up any data.
Either way, while more convoluted, that strategy does work.
or maybe make it a TrollStore app/jailbroken tweak?
I can confirm, the app, Opal, does not use use convoluted and hard to set up workarounds to get the data, or at least nothing visible I am aware of.
It is able to access screen time data out of the box, I use it, and it is not jailbroken or anything.
I would include screenshots, but I set a password within the app after setting up my blocks and kinda forgot it lol
Does it allow exporting the data like AW does?
