Hi everyone. I’m new here, and also into the “code” world. I’ve started coding since October’s 2025 using AI. I’ve started to build a productivity tracker and found AW. It’s a very useful tool, but it’s hard to integrate the data that come from ANDROID with PC. I’m using a script with termux on my android device to send the data to pc (using foldersync) but it crashes sometimes. I belive that integration is the key to unlock the real power of this tool, but it’s not easy for me. Anyone have any idea ?
This is already done in the new release of aw-android. You can check the beta at GitHub - 0xbrayo/aw-android: ActivityWatch for Android, using aw-server-rust as backend.
