Hi, this is my first post here and first of all thanks for this great application.
I’m using Archlinux and i3 window manager on latest releases and I start aw-qt from i3 config exec --no-startup-id aw-qt
The activitywatch works as expected, but see numerous such errors in my journal log. Is there a way to fix this problem, or is this a bug?
systemd-coredump[1237]: [🡕] Process 1189 (aw-qt) of user 1000 dumped core.
Found module linux-vdso.so.1 with build-id: 56662b5ca343f56368dec1e53ca77d098c25a9a3
Found module QtGui.abi3.so with build-id: 3c625df518085deaf8a53ef6e145a0e4d4c9910c
Found module librt.so.1 with build-id: 75484da2d6f1515189eefa076e0a40328834cd16
Found module libbsd.so.0 with build-id: 5778a8a28ec1c4b154ce0d9c35686f082c41284a
Found module libXdmcp.so.6 with build-id: f35e3e5ff3fede9b4a4715aebd4677f356fc3ce9
Found module libXau.so.6 with build-id: 571d2c0a08a78e9afbb7fc8e927e7fe9e6e60663
Found module libxcb.so.1 with build-id: 0d1ef11740a5daad2ee331e812a51aa6574af222
Found module libX11.so.6 with build-id: 4124168452d079d48767ebadd480872381d71faa
Found module libGLX.so.0 with build-id: 0f40ceaa036edc65147e9559b94e0219472493fc
Found module libGLdispatch.so.0 with build-id: 195b34c1bb271f3b1162c897cfbcfb859e656b93
Found module libGL.so.1 with build-id: 8b3028bab286029945569a0dfcf695f0f61d9c3b
Found module libQt5Gui.so.5 with build-id: bffe8076fee9a98e38828285a64e0b7672b377c8
Found module libQt5Widgets.so.5 with build-id: 040d62583201617c9d5024a20abcae366f124864
Found module QtWidgets.abi3.so with build-id: d6b4171da7272f5a058e312b9925ca6d37f47154
Found module _decimal.cpython-38-x86_64-linux-gnu.so with build-id: a0160009ffd234df95fdf1>
Found module _json.cpython-38-x86_64-linux-gnu.so with build-id: 2888bf61e214f26734670593a>
Found module sip.cpython-38-x86_64-linux-gnu.so with build-id: 2fafde96285279c5b52401780b0>
Found module libpcre.so.3 with build-id: 0430be99fc9b58fd796fbc39a60bc84fadc8117e
Found module libgcc_s.so.1 with build-id: bd65568e16152250ad2603921963e1367fcaa785
Found module libglib-2.0.so.0 with build-id: 92332a61e822451cb8fa883f1c4cdb39dabd14d3
Found module libgthread-2.0.so.0 with build-id: cb1124dfb8dbf9253619c3c89662851047dfb700
Found module libicudata.so.56 with build-id: 34aac32bb4d3c0f44e72e57cf253a871240a1154
Found module libicuuc.so.56 with build-id: 80916a3578c4abf8d9433986b7ca87ee58797eb5
Found module libicui18n.so.56 with build-id: ea6a2369dae8e186543b5e0fa413cb7ee7058c84
Found module libstdc++.so.6 with build-id: b9e395f94796e963124fbed84554da09711827af
Found module libQt5Core.so.5 with build-id: 7e528ef9a04c67ed3f2b173a8fe86169032b4dd7
Found module QtCore.abi3.so with build-id: 1de75dbbf43d752e8b554f41917019981a6ed2ca
Found module _opcode.cpython-38-x86_64-linux-gnu.so with build-id: 40028dce9a62087e77ff49b>
Found module _random.cpython-38-x86_64-linux-gnu.so with build-id: c600fdc80d90427c3dcd655>
Found module _sha512.cpython-38-x86_64-linux-gnu.so with build-id: 8295443b1d5e3f82c106aaa>
Found module _bisect.cpython-38-x86_64-linux-gnu.so with build-id: 91a523133c6bf9d9605ed13>
Found module pyexpat.cpython-38-x86_64-linux-gnu.so with build-id: cd329b4ad829a36813fdb4f>
Found module _datetime.cpython-38-x86_64-linux-gnu.so with build-id: faef0e5de4c057c2c7b7c>
Found module grp.cpython-38-x86_64-linux-gnu.so with build-id: 873cc5d0b2c37caf9bcd8f56875>
Found module liblzma.so.5 with build-id: 8fbcca354d964860b9e6eb3736e9b7bc6177b417
Found module _lzma.cpython-38-x86_64-linux-gnu.so with build-id: 3e3a69c280e7674901ab2189f>
Found module libbz2.so.1.0 with build-id: a4147045409ed969e6f3936f3726726f4719bb40
Found module _bz2.cpython-38-x86_64-linux-gnu.so with build-id: e6b65661ea837b28db8689531a>
Found module binascii.cpython-38-x86_64-linux-gnu.so with build-id: 56608759e4ac065ffee559>
Found module _posixsubprocess.cpython-38-x86_64-linux-gnu.so with build-id: 2bd26616a7c07d>
Found module array.cpython-38-x86_64-linux-gnu.so with build-id: ce49246d6031d8125de66cbd9>
Found module select.cpython-38-x86_64-linux-gnu.so with build-id: f995d574c98da0794247e9a1>
Found module math.cpython-38-x86_64-linux-gnu.so with build-id: e894d3830412f08c95abd67edd>
Found module _socket.cpython-38-x86_64-linux-gnu.so with build-id: a5d48d0e7428517cf37ccf5>
Found module _pickle.cpython-38-x86_64-linux-gnu.so with build-id: 4e1453dfe00e9148bd92e04>
Found module _heapq.cpython-38-x86_64-linux-gnu.so with build-id: 9423529680c10c08208a44b5>
Found module libffi.so.6 with build-id: 3555b5f599c9787dfddbf9e8df6f706b9044d985
Found module _ctypes.cpython-38-x86_64-linux-gnu.so with build-id: 0fedf1281354057842d758d>
Found module zlib.cpython-38-x86_64-linux-gnu.so with build-id: 49d28af9c5b65e8ca458065aa5>
Found module _struct.cpython-38-x86_64-linux-gnu.so with build-id: bce82704a7e9aa190ab0e4f>
Found module libm.so.6 with build-id: 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Found module libutil.so.1 with build-id: af6d8200064ee6e6a01252884d166b44f0a6121b
Found module libpython3.8.so.1.0 with build-id: 81752d2bbe6216ad347347da1d9d6ec7c8e71738
Found module ld-linux-x86-64.so.2 with build-id: 040cc3dd10461562f177df39e3be2f3704258c3c
Found module libc.so.6 with build-id: 4b406737057708c0e4c642345a703c47a61c73dc
Found module libpthread.so.0 with build-id: 07c8f95b4f3251d08550217ad8a1f31066229996
Found module libz.so.1 with build-id: ef3e006dfe3132a41d4d4dc0e407d6ea658e11c4
Found module libdl.so.2 with build-id: 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Found module aw-qt with build-id: 24675b0091f38f45c5c1c5484cf24925b439b164
Stack trace of thread 1189:
#0 0x00007f1100c99d22 raise (libc.so.6 + 0x3cd22)
#1 0x00007f1100c83862 abort (libc.so.6 + 0x26862)
#2 0x00007f10fc18c9bc _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x929bc)
#3 0x00007f10f744efa0 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui>
#4 0x00007f10f744f2ad _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.>
#5 0x00007f10fc39efe3 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x2a4fe3)
#6 0x00007f10f7451ccc _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x16accc)
#7 0x00007f10f7d7faa9 _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x167aa9)
#8 0x00007f10f870531d n/a (QtWidgets.abi3.so + 0x28b31d)
#9 0x00007f10f87053fb n/a (QtWidgets.abi3.so + 0x28b3fb)
#10 0x00007f10f910a1c6 n/a (sip.cpython-38-x86_64-linux-gnu.so + 0x1d1c6)
#11 0x00007f110083290e n/a (libpython3.8.so.1.0 + 0x17190e)
#12 0x00007f11007f4194 _PyObject_MakeTpCall (libpython3.8.so.1.0 + 0x133194)
#13 0x00007f110086be5f _PyEval_EvalFrameDefault (libpython3.8.so.1.0 + 0x1aae5f)
#14 0x00007f110086713d _PyEval_EvalCodeWithName (libpython3.8.so.1.0 + 0x1a613d)
#15 0x00007f11007f4975 _PyFunction_Vectorcall (libpython3.8.so.1.0 + 0x133975)
#16 0x00007f1100868ac9 _PyEval_EvalFrameDefault (libpython3.8.so.1.0 + 0x1a7ac9)
#17 0x00007f1100866c61 _PyEval_EvalCodeWithName (libpython3.8.so.1.0 + 0x1a5c61)
#18 0x00007f11007f4975 _PyFunction_Vectorcall (libpython3.8.so.1.0 + 0x133975)
#19 0x00007f11007f58b0 PyVectorcall_Call (libpython3.8.so.1.0 + 0x1348b0)
#20 0x00007f1100869a4b _PyEval_EvalFrameDefault (libpython3.8.so.1.0 + 0x1a8a4b)
#21 0x00007f1100866c61 _PyEval_EvalCodeWithName (libpython3.8.so.1.0 + 0x1a5c61)
#22 0x00007f11007f4975 _PyFunction_Vectorcall (libpython3.8.so.1.0 + 0x133975)
#23 0x00007f11007f6d04 n/a (libpython3.8.so.1.0 + 0x135d04)
#24 0x00007f11007f58b0 PyVectorcall_Call (libpython3.8.so.1.0 + 0x1348b0)
#25 0x00007f1100869a4b _PyEval_EvalFrameDefault (libpython3.8.so.1.0 + 0x1a8a4b)
#26 0x00007f11007f48e1 _PyFunction_Vectorcall (libpython3.8.so.1.0 + 0x1338e1)
#27 0x00007f1100868146 _PyEval_EvalFrameDefault (libpython3.8.so.1.0 + 0x1a7146)
#28 0x00007f1100866c61 _PyEval_EvalCodeWithName (libpython3.8.so.1.0 + 0x1a5c61)
#29 0x00007f11007f4975 _PyFunction_Vectorcall (libpython3.8.so.1.0 + 0x133975)
#30 0x00007f11007f6c70 n/a (libpython3.8.so.1.0 + 0x135c70)
#31 0x00007f11007f58b0 PyVectorcall_Call (libpython3.8.so.1.0 + 0x1348b0)
#32 0x00007f1100869a4b _PyEval_EvalFrameDefault (libpython3.8.so.1.0 + 0x1a8a4b)
#33 0x00007f1100866c61 _PyEval_EvalCodeWithName (libpython3.8.so.1.0 + 0x1a5c61)
#34 0x00007f11007f3ecb _PyObject_FastCallDict (libpython3.8.so.1.0 + 0x132ecb)
#35 0x00007f11007f5521 _PyObject_Call_Prepend (libpython3.8.so.1.0 + 0x134521)
#36 0x00007f1100837ee9 n/a (libpython3.8.so.1.0 + 0x176ee9)
#37 0x00007f11007f4194 _PyObject_MakeTpCall (libpython3.8.so.1.0 + 0x133194)
#38 0x00007f110086be5f _PyEval_EvalFrameDefault (libpython3.8.so.1.0 + 0x1aae5f)
#39 0x00007f1100866c61 _PyEval_EvalCodeWithName (libpython3.8.so.1.0 + 0x1a5c61)
#40 0x00007f110086697c PyEval_EvalCodeEx (libpython3.8.so.1.0 + 0x1a597c)
#41 0x00007f110086693b PyEval_EvalCode (libpython3.8.so.1.0 + 0x1a593b)
#42 0x00005632039f8ca3 n/a (aw-qt + 0x3ca3)
#43 0x00005632039f909f n/a (aw-qt + 0x409f)
#44 0x00007f1100c84b25 __libc_start_main (libc.so.6 + 0x27b25)
#45 0x00005632039f750a n/a (aw-qt + 0x250a)
systemd-coredump[1277]: [🡕] Process 1183 (aw-qt) of user 1000 dumped core.
Found module libz.so.1 with build-id: 81bf6e728a6d6f5b105b0f8b25f6c614ce10452a
Stack trace of thread 1183:
#0 0x00007fa495786702 raise (libpthread.so.0 + 0x13702)
#1 0x000055a8fa042213 n/a (aw-qt + 0x6213)
#2 0x000055a8fa04015d n/a (aw-qt + 0x415d)
#3 0x00007fa4955ceb25 __libc_start_main (libc.so.6 + 0x27b25)
#4 0x000055a8fa03e50a n/a (aw-qt + 0x250a)
