Hello.
ActivityWatch does not start on MacOS Monterey. Just nothing happens
I’d try the following:
- Start it from a terminal, and see if you get any error (if you do, please paste it here).
- Make sure to check the list of processes to see if AW is running, or which components are running.
- Check logs if any related to this
- No errors when AW starting from terminal. Only standard security warnings at first start AW:
- In Process Monitor - no any launched processes similar to AW
- Where can I also get any information and logs then AW startup?
I’m having the same problem and would love to troubleshoot! Whether or not I start from terminal does not have an effect. Activity Monitor shows that that AW is running–but I can’t actually access the program in any way. It doesn’t actually open. Any ideas?
Same issue - AW not starting. Is this ever going to be fixed because I see the thread is pretty old.
