Menubar start/stop for stopwatch
I just found ActivityWatch while looking for an alternative to Toggl, and I’m shocked that it does so much! One smallish thing that I’m surprised is missing though is an easy, one-click/shortcut way to control the stopwatch.
Would it be possible to have a start/stop option in the menubar icon? Again, something similar to Toggl. I guess this would also go with features like “explicit tracking” or “stopwatch pause”.
If you use Windows, then in the system tray you can disable and enable modules.
In MacOS I also have the modules in the menubar icon, but I don’t see anything about the stopwatch there.
Hi,
I’m just discovering ActivityWatch. It looks very great. :love_letter:
But effectively, it seems missing a Stopwatch buttons in the tray icon. I found some old thread here about it but no solution. Did you find other apps which interact with the ActivityWatch’s StopWatch ?
Regards & cheers
