I recently downloaded ActivityWatch for Mac running 11.7.9, Intel
Upon starting the app I get a Native Box saying:
“Module aw-watcher-window quit unexpectedly”
With the following details:
2023-08-11 10:43:18 [INFO ]: aw-watcher-window started (aw_watcher_window.main:62)
2023-08-11 10:43:19 [INFO ]: Using swift strategy, calling out to swift binary (aw_watcher_window.main:67)
2023-08-11 10:43:19 [INFO ]: Connection to aw-server established by aw-watcher-window (aw_client.client:436)
Restarting aw-watcher-window does not help me.
ie) The checkbox for aw-watcher-window does not show a checkmark.
I was curious and went through attempting to build the software myself.
Running make build
yielded issues with the macOS version I am on:
aw_watcher_window/macos.swift:192:53: error: 'upload(for:from:delegate:)' is only available in macOS 12.0 or newer
aw_watcher_window/macos.swift:258:51: error: 'upload(for:from:delegate:)' is only available in macOS 12.0 or newer
aw_watcher_window/macos.swift:295:24: error: 'now' is only available in macOS 12 or newer
let nowTime = Date.now
Also a couple of “note: add ‘if #available’ version check”
I tried doing
if #available(macOS 12.0, *) {
// Code that uses macOS 12.0 APIs
} else {
// Code for older macOS versions
Any recommendations?
I’ve yet to see the full capabilities of ActivityWatch and am excited to see how it all works!
