Since a few days i am receiving error messages like: Module aw-watcher-widow quit unexpectedly. I removed en re-installed but the error persists.
Am i doing something wrong?
There is not enough information here for us to help you unfortunately.
What operating system are you using? Can you give us the logs when it crashes? I assume you use the latest version, if not please specify which version.
Hi, Yes i am using the newest version (downloaded it, hoping the error would disappear) I use Windows 10 Pro vs 1909. There is no recent log-file for the Module aw-watcher-afk (The latest is empty and the one before is attached) Same goes for the Module aw-watcher-window. Please advise how to upload these log files, since i cannot opload log-extension
Open it in a text editor such as notepad and copying the last few lines should be enough.
Hi, below you’ll find the latest logs. The problem started on april 27 i assume. If you need more data, please let me know.
aw-qt
2020-05-07 12:35:28 [WARNING]: Tried to stop module aw-watcher-window, but it wasn’t running (aw_qt.manager:87)
2020-05-08 09:07:50 [INFO ]: Starting module aw-watcher-window (aw_qt.manager:49)
2020-05-08 09:07:53 [WARNING]: Tried to stop module aw-watcher-window, but it wasn’t running (aw_qt.manager:87)
aw-server
2020-05-07 12:35:20 [INFO ]: Using storage method: peewee (aw_server.main:26)
2020-05-07 12:35:20 [INFO ]: Starting up… (aw_server.main:31)
2020-05-07 12:35:20 [INFO ]: Using database file: C:\Users\erik\AppData\Local\activitywatch\activitywatch\aw-server\peewee-sqlite.v2.db (aw_datastore.storages.peewee:90)
2020-05-07 12:35:20 [INFO ]: * Running on http://localhost:5600/ (Press CTRL+C to quit) (werkzeug:122)
aw-watcher-window
2020-04-24 11:44:59 [INFO ]: aw-watcher-window started (aw_watcher_window.main:42)
2020-04-24 11:45:01 [INFO ]: Connection to aw-server established by aw-watcher-window (aw_client.client:348)
2020-04-26 04:10:49 [WARNING]: Failed to send request to aw-server, will queue requests until connection is available. (aw_client.client:370)
2020-04-26 04:10:49 [WARNING]: Not connected to server, 0 requests in queue (aw_client.client:380)
2020-04-26 04:10:59 [INFO ]: Connection to aw-server established by aw-watcher-window (aw_client.client:348)
aw-watcher-afk
2020-04-25 15:26:55 [INFO ]: Became AFK (aw_watcher_afk.afk:89)
2020-04-26 04:08:01 [INFO ]: No longer AFK (aw_watcher_afk.afk:83)
2020-04-26 04:13:55 [INFO ]: Became AFK (aw_watcher_afk.afk:89)
2020-04-26 18:25:16 [INFO ]: No longer AFK (aw_watcher_afk.afk:83)
2020-04-26 19:02:27 [INFO ]: Became AFK (aw_watcher_afk.afk:89)
