What are the modules? I’ve observed that my modules quit unexpectedly when I restart my PC. The module aw-server-rust always says “quit unexpectedly”.
Modules are simply different components needed for ActivityWatch to work.
There can only be one server running at the same time, either aw-server or aw-server-rust. You should only use aw-server-rust if you know what you are doing as it’s there for testing purposes right now.
If any nother modules fails, press the button for more info and paste it here if you need help.
