Hey there, just installed and no matter what the server won’t start. Tried running as admin and didn’t make a difference. Logs are below for the main qt log. Checked logs for the other cores and they basically just say “not connected to server”. Also tried manually running the aw-server.exe in local\programs\activitywatch\aw-server didn’t seem to do anything. Not sure if maybe my install is somehow messed up or if I have something conflicting.
Main qt log:
2023-01-05 11:46:30 [INFO ]: Started aw-qt... (aw_qt.main:53) 2023-01-05 11:46:30 [WARNING]: Found matching file but was not executable: C:\Users\jallw\AppData\Local\Programs\ActivityWatch\aw-qt.desktop (aw_qt.manager:64) 2023-01-05 11:46:30 [WARNING]: Found matching file but was not executable: C:\Users\jallw\AppData\Local\Programs\ActivityWatch\aw-server-rust\aw-server.service (aw_qt.manager:64) 2023-01-05 11:46:30 [INFO ]: Found 4 bundled modules (aw_qt.manager:85) 2023-01-05 11:46:30 [INFO ]: Found 0 system modules (aw_qt.manager:119) 2023-01-05 11:46:30 [INFO ]: Starting module aw-server (aw_qt.manager:148) 2023-01-05 11:46:30 [INFO ]: Starting module aw-watcher-window (aw_qt.manager:148) 2023-01-05 11:46:30 [INFO ]: Starting module aw-watcher-afk (aw_qt.manager:148) 2023-01-05 11:46:30 [INFO ]: Creating trayicon... (aw_qt.trayicon:206) 2023-01-05 11:46:30 [INFO ]: Initialized aw-qt and trayicon successfully (aw_qt.trayicon:262) 2023-01-05 11:46:32 [WARNING]: Tried to stop module aw-server, but it wasn't running (aw_qt.manager:185) 2023-01-05 11:46:38 [INFO ]: Starting module aw-server (aw_qt.manager:148)
aw-server log:
2023-01-05 11:34:42 [INFO ]: Using storage method: peewee (aw_server.main:33) 2023-01-05 11:34:42 [INFO ]: Starting up... (aw_server.main:41) 2023-01-05 11:34:42 [INFO ]: Using database file: C:\Users\jallw\AppData\Local\activitywatch\activitywatch\aw-server\peewee-sqlite.v2.db (aw_datastore.storages.peewee:126)
