Periodic Activity Reports
I may be using this in a much simpler way. But I would like to enter a period, say this week or a date range, and have it display a report showing all activity or active time on the computer. For me, I am not worried about what was done, but just the time the PC was active.
Is this possible? It would be nice to customize a report and auto-send it, but being able to justify the hours on a computer works for me.
There’s the report feature http://localhost:5600/#/report on the newer beta releases. You need to first toggle on “Force devmode” in the settings
I like that, but when I try to run the beta version, I keep having a lot of errors. It seemed like PC was blocking some script, so I went back to the current version.
Maybe I will spend some time trying to put it into dev mode.
There’s a new stable release since my last comment, what are the odds. Check it out here you can also use a standalone binary such aw-work-sync if you prefer.
Before spending time forcing devmode, try the new stable build brayo mentioned. If the beta errors were your PC blocking a local script, the stable release is the lower-friction path and should still expose the report/date-range view if it’s included. If the report only shows app breakdowns and not a total active-time figure, say so—that distinction matters for whether the existing report meets your simple use case.
