I was trying to install from source following Installing from source but whenever I run the make command it generates .cmd files on windows.
Which causes issues because we look for .exe files later on I think. Am I doing something wrong?
What’s the issue exactly?
If you ran make, it will tell you if it failed or succeeded. Whatever make tells you is what’s interesting if it did not succeed.
