Hi, new to the app. And quickly found myself really enjoying using it.
I’d like to have Prometheus metrics. Like at http://localhost:5600/metrics
sounds good.
It would be like exposing the current data statistics on the endpoint.
Probably I can use the API to fetch data and create an exporter externally, but build-in solution should be better.
That’s all. Thank you!
