import os, requests
username = os.environ.get('USERNAME')
directory = f"C:\\Users\\{username}\\OneDrive"
aw_url = "http://localhost:5600/api/0/export"
def export():
os.makedirs(directory, exist_ok=True)
path = os.path.join(directory, f"{os.environ['COMPUTERNAME']}.json")
response = requests.get(aw_url)
response.raise_for_status()
with open(path, "wb") as f:
f.write(response.content)
print(f"Export saved to: {path}")
export()
from aw_client import ActivityWatchClient
import os, requests, enum
class MSG(enum.Enum):
impj = 'Importing {lenfile} JSON files to ActivityWatch...'
Erdir = 'Error: Directory {directory} does not exist!'
impsuc = 'Success: File imported {filename}'
impsuce = 'Success: File imported {filename} with {events_count} events imported'
comp = 'COMPLETE! Total files processed: {lenfile}'
view = 'View in ActivityWatch: http://localhost:5600/#/buckets'
er = 'AW Server not run'
dbucket = 'Deleted: {bucket}'
fbucket = 'Failed {bucket}: {e}"'
process = 'Processing: {filename}'
aw_import_url = "http://localhost:5600/api/0/import"
json_files = [f for f in os.listdir(directory) if f.lower().endswith('.json')]
auth_file = f"C:\\Users\\{username}\\AppData\\Roaming\\aw-client\\auth"
def update():
print(MSG.impj.value.format(lenfile=len(json_files)))
if not os.path.exists(directory):
print(MSG.Erdir.value.format(directory=directory))
return
total_events = 0
for filename in json_files:
full_path = os.path.join(directory, filename)
print(MSG.process.value.format(filename=filename))
try:
with open(full_path, "r", encoding="utf-8") as f:
body = f.read()
response = requests.post(aw_import_url, data=body.encode("utf-8"), headers={"Content-Type": "application/json"},)
try:
resp_json = response.json()
except ValueError:
resp_json = None
if isinstance(resp_json, dict) and "events" in resp_json:
events_count = len(resp_json["events"])
total_events += events_count
print(MSG.impsuce.value.format(filename=filename, events_count=events_count))
else:
print(MSG.impsuc.value.format(filename=filename))
except Exception as e:
print(f" Error: {e}")
print(MSG.comp.value.format(lenfile=len(json_files)))
print(MSG.view.value)
def delete():
if os.path.exists(auth_file):
with open(auth_file, 'r') as f:
auth_line = f.read().strip()
os.environ['AW_CLIENT_AUTH'] = auth_line
client = ActivityWatchClient('deleter')
try:
buckets = client.get_buckets()
for bucket_id in list(buckets.keys()):
try:
client.delete_bucket(bucket_id, force=True)
print(MSG.dbucket.value.format(bucket=bucket_id))
print(MSG.fbucket.value.format(bucket=bucket_id, e=e))
except:
print(MSG.er.value)
delete()
update()
maybe someone need it <3
in my case i use OneDrive for reasons and its better for me.
import script will delete every buckets and then import it again and files names use computer name just like bucket name in AW.
and also import code whil import every JSON file in that directory.
