How can I Remove activitywatch from Win 10?
The primary thing to delete is the activitywatch folder in “Program Files” where the application itself resides.
The database where all data is stored is in %appdata%\activitywatch\activitywatch
Then how to remove the startup sortcut and the autostart feature I’m not completely sure actually.
We should probably document better where all files are stored so people can easily remove all files and possibly a script/program which uninstalls/removes it.
Startup Applications for system install can be found in
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp
While for users it’s found in
%appdata%\Microsoft\Windows\Start Menu\Programs\Startup
So I would wager removing the program shortcut from there will handle it on next reboot. (Mine is located in the user folder, fwiw)
