How to run ActivityWatch in Visual studio taken from github.
Please help us regarding this
There is one for visual studio code here, which is the only one I’ve tested:
https://marketplace.visualstudio.com/items?itemName=lindraupe.aw-watcher-vscode
Then there’s another one for the classic visual studio, but I have not verified that it works:
https://marketplace.visualstudio.com/items?itemName=FlorianLagg.ActivityWatchVS
There is a “Download” button for both which should work. In visual studio code though you can install it right from the editor if you want.
Thank you and i would like to know where will the execution starts from, the starting file of exectuion in entire application
The actual activitywatch application or the visual studio watcher?
aw-server starts here: https://github.com/ActivityWatch/aw-server/blob/master/aw_server/main.py
The watcher itself I don’t know as I have not written it, but the source code is here: https://github.com/LaggAt/ActivityWatchVS
Hi, I’m the dev of the VS watcher, have you found what you are looking for?
