Hello, I was wondering how i can set the rust implementation of the server to be the default on windows.
It is installed by default, but not autostarted.
There should be a config file for aw-qt where you can configure which modules are autostarted.
I think on windows that would be at the following path: C:\Users\<USER>\AppData\Local\activitywatch\activitywatch\aw-qt\aw-qt.toml
