opened 04:12PM - 16 Jun 21 UTC
closed 07:11AM - 17 Jun 21 UTC
type: bug
- [x] I am on the [latest](https://github.com/ActivityWatch/activitywatch/relea…ses/latest) ActivityWatch version.
- [x] I have searched the issues of this repo and believe that this is not a duplicate.
**OS name and version**: Ubuntu 20.10
**ActivityWatch version**: v0.11.0
## Describe the bug
After updating to v0.11.0, I get the following error message, when changing the `duration default value` under http://127.0.0.1:5600/#/settings: `TypeError: t.target is undefined. See dev console (F12) and/or server logs for more info.`
Here's the relevant part of the log:
2021-06-16 17:04:53 [INFO ]: Using storage method: peewee (aw_server.main:32)
2021-06-16 17:04:53 [INFO ]: Starting up... (aw_server.main:37)
2021-06-16 17:04:53 [INFO ]: Using database file: /home/sojusnik/.local/share/activitywatch/aw-server/peewee-sqlite.v2.db (aw_datastore.storages.peewee:116)
2021-06-16 17:04:53 [INFO ]: * Running on http://localhost:5600/ (Press CTRL+C to quit) (werkzeug:113)
2021-06-16 17:05:09 [INFO ]: Received heartbeat after pulse window, inserting as new event. (bucket: aw-watcher-afk_mir) (aw_server.api:262)
2021-06-16 17:05:36 [INFO ]: 404 (127.0.0.1): [33mGET /img/icons/apple-touch-icon-152x152.png HTTP/1.1[0m (flask:25)
2021-06-16 17:06:03 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:06:03 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:06:03 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:06:03 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:06:03 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:08:19 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:08:19 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:08:19 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:08:19 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:08:19 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:09:09 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:09:09 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:09:09 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:09:09 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:09:09 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:21:59 [INFO ]: 404 (127.0.0.1): [33mGET /img/icons/apple-touch-icon-152x152.png HTTP/1.1[0m (flask:25)
2021-06-16 17:22:01 [INFO ]: 308 (127.0.0.1): [32mGET /api HTTP/1.1[0m (flask:25)
2021-06-16 17:23:28 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:23:28 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:23:28 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:23:28 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:23:28 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:24:15 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:24:34 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:24:42 [WARNING]: Gap was of negative duration but could be safely merged (-3222.408s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:24:50 [WARNING]: Gap was of negative duration but could be safely merged (-3507.265s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:25:33 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:25:33 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:25:33 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:25:33 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:25:33 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:11 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-511.164s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-185.183s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-1037.105s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-195.22s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-4173.679s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-15374.187s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-280.543s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-250.3s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-0.001s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration and could NOT be safely merged (-606.488s). This warning will only show once per batch. (aw_transform.flood:54)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-190.213s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-411.043s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-3507.265s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-295.56s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-305.553s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:17 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:21 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:22 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:24 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:25 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:32:28 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-3507.265s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-295.56s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-3222.408s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-315.46s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-300.66s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-887.087s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-305.553s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:36:40 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:38 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:38 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:38 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:38 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:38 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:58 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:58 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:58 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:58 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:37:58 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:16 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:16 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:16 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:16 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:16 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:57 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:57 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:57 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:57 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:38:57 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:39:16 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:39:16 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:39:16 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:39:16 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:39:16 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:40:37 [INFO ]: 404 (127.0.0.1): [33mGET /img/icons/apple-touch-icon-152x152.png HTTP/1.1[0m (flask:25)
2021-06-16 17:41:00 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:00 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:00 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:00 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:00 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:23 [ERROR]: Exception on /api/0/query/ [POST] (aw-server:1891)
File "flask/app.py", line 1950, in full_dispatch_request
File "flask/app.py", line 1936, in dispatch_request
File "flask_restx/api.py", line 375, in wrapper
File "flask/views.py", line 89, in view
File "flask_restx/resource.py", line 44, in dispatch_request
File "aw_server/rest.py", line 280, in post
File "aw_server/api.py", line 290, in query2
File "iso8601/iso8601.py", line 195, in parse_date
iso8601.iso8601.ParseError: Unable to parse date string 'Invalid date'
2021-06-16 17:41:23 [INFO ]: 500 (127.0.0.1): [35m[1mPOST /api/0/query/ HTTP/1.1[0m (flask:25)
2021-06-16 17:41:24 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:24 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:24 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:24 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:41:24 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:03 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:03 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:03 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:03 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:03 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:25 [WARNING]: Gap was of negative duration but could be safely merged (-887.087s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:25 [WARNING]: Gap was of negative duration but could be safely merged (-305.553s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:25 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:25 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:25 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:25 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:25 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:37 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:47 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:58 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:58 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:58 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:58 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:42:58 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:10 [WARNING]: Gap was of negative duration but could be safely merged (-305.553s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:10 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:10 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:10 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:10 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:10 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:30 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:37 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:48 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:55 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:56 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:56 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:56 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:56 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:44:56 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:45:06 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:02 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:02 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:02 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:02 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:02 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:04 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:16 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:27 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:36 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:36 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:36 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:36 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:36 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:36 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:46 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:53 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:53 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:53 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:53 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:49:53 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:53:04 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:53:14 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:53:22 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:53:22 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:53:22 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:53:22 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 17:53:22 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 18:03:34 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 18:03:44 [WARNING]: Gap was of negative duration but could be safely merged (-5.003s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 18:03:51 [WARNING]: Gap was of negative duration but could be safely merged (-48489.32s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 18:03:51 [WARNING]: Gap was of negative duration but could be safely merged (-9158.248s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 18:03:51 [WARNING]: Gap was of negative duration but could be safely merged (-2526.657s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 18:03:51 [WARNING]: Gap was of negative duration but could be safely merged (-335.78s). This message will only show once per batch. (aw_transform.flood:46)
2021-06-16 18:03:51 [WARNING]: Gap was of negative duration but could be safely merged (-365.592s). This message will only show once per batch. (aw_transform.flood:46)
