After installing the Firefox extension I can’t make a connection to the aw-server.
Connected:
aw-server is running, and is running without problems. I can connect with the new edge extension. aw-watcher-web-firefox shows in the ActivityWatch Buckets, but there is no raw data (Eventcount: 0).
Debugging of the app indicates the following errors:
TypeError: PrecompiledScript.executeInGlobal: Argument 1 is not an object. 2 ExtensionContent.jsm:568:25
Unchecked lastError value: Error: ID already exists: open-browser-action 10 ExtensionCommon.jsm:764
withLastError resource://gre/modules/ExtensionCommon.jsm:764
create chrome://browser/content/child/ext-menus.js:148
Some comments:
I am running Firefox: “In permanent private browsing mode, cookies and site data will always be cleared when Firefox is closed.”
Furthermore settings are as follows:
When Firefox is set to remember history, the connection is fine and data is received on the server.
If set to Never Remember History, no data is received. Probably because “Firefox will use the same settings as private browsing, and will not remember any history as you browse the Web.”
That’s very interesting, had no idea that setting could change the behavior of the extension APIs we are using. Will need to continue looking into this more. I’ll re-open the Github issue.
We never look at the browsing history in aw-watcher-web, we only look at the title and URL of the tab when you switch tabs. So it’s surprising (but certainly possible) that it does not work as expected with that setting changed.
