Hello and thank tour for the nice job you are doing with ActivityWatch.
I would need a help about what I’m doing wrong: OS windows 10, I installed web watcher on my browsers:
- Firefox and it works well
- Edge with the extension of chrome, unexpectedly it works, I cannot see results in /#/activity/Pc-E/browser but I can see in #/timeline so for me is enough
- Chrome: this doesn’t work, I get the notification that it could non send event to server and to verify it is running but… if the same watcher works on Edge I’m quite sure it is working so I bet there is any other problem maybe on chrome authorization. Extension si configured to access to http://localhost:5600/* and http://localhost:5666/*
telnet to localhost 5600 works
chrome version: Versione 85.0.4183.83 (Build ufficiale) (a 64 bit)
thnak you for any help you will be able to give me
Regards
Enrico
