Hi,
I like this tool a lot. It is very useful for my work. But for a longer period I will not need to monitor my work. I would like to uninstall. Is there a preferred way to uninstall it? There is no information in the documentation. (Pop!_OS)
Thank you for your help!
Depends on how you installed it.
Assuming you installed by simply unpacking the zip: If you simply want to remove ActivityWatch itself you can just remove the files from where you unpacked them.
If you also want to remove the data that it stores you can delete the data directory (and optionally config, cache, and logs directory). Their location is specified in the documentation: https://docs.activitywatch.net/en/latest/directories.html
