The category builder seems to not be working properly. I’m not sure what I am doing wrong.
Unable to find bucket matching ‘aw-watcher-window_unknown’ (hostname filter set to ‘None’)
I think this is a duplicate of "High uncategorized time".
I had the same issue.
I noticed there was an options button.
I clicked on it and the expanded options had a Hostname option set to None.
I clicked on that and saw the name of my device.
I clicked on that and the issue was resolved for me.
Hope that helps you.
Cheers
Exactly the answer I was looking for. Thanks
I don’t seem to be able to save the name of my device. It keep going back to unknown.
