Hi,
thanks very much for developing this applicaiton and sharing it for free. I have been using the software for >4months, and I really enjoyed it a lot. At the same time, I would also like to contribute to project in some way, so I try to install the souce code on my PC, but I run into some issues.
Does anyone by chance know if installing from source codes on WSL works as well?
I am following the tutorial to install the souce code on my WSL, I successfully followed through all the steps before “make build”. But when I run “make build”, it was not successful because of " Installing evdev (1.4.0): Failed".
The error is related with the following issues:
The ‘linux/input.h’ and ‘linux/input-event-codes.h’ include files
are missing. You will have to install the kernel header files in
order to continue:
yum install kernel-headers-$(uname -r)
apt-get install linux-headers-$(uname -r)
emerge sys-kernel/linux-headers
pacman -S kernel-headers
I tried these commands, but they doesn’t work. So i am curious to know if this is a general issue for all WSL(i.e. dose the installing also works on WSL) or just a issue for myself.
If anyone has installed the souce codes successfuly on WSL, please let me know. Thanks in advance!
Kind Regards,
Eric
